Is this stock?
Old Mar 21, 2001 | 07:46 AM
Imark's Avatar
Is this stock?
I've got an '84 Z28 vin (H) but it's got two mufflers. I wanted to go to a Flowmaster or somthing but all I can find is a single muffler system.
My exhaust runs from the cat, splits into two 2" pipes one to each muffler. The mufflers have a cross-over tube between them then they exit to two exhaust pipes. What is this?
"It's not about going fast all the time; It's knowing you can, anytime"
Old Mar 21, 2001 | 08:13 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
What the ****!? That has got to be one of the wildest thigs I've ever heard. Any ways, the answer to your Q is yes. The stock setup should only have 1 pipe coming from the cat/cats leading into a transverse muffler. You cna change to a flowmaster setup with no problems. But wait, maybe consider keeping your current configuration and installing 2 flowmasters instead of using the transverse version. Flow will be better and it might sound differnet also. Then even consider putting dual cats on(if your car only has 1) and making it a true dual exhaust setup. Hope my rambling helps!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
[This message has been edited by CraZ-28 (edited March 21, 2001).]
Old Mar 21, 2001 | 10:08 AM
FormulaJoe's Avatar
That type of exhaust came on some early thirdgen TAs and Z28s (82-84 maybe). Used small diameter pipe into two mufflers.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old Mar 21, 2001 | 10:21 AM
CraZ-28's Avatar
Car: 1991 Z-28
I stand corrected, I guess you learn something new everyday.
Old Mar 21, 2001 | 10:30 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
<font face="Verdana, Arial" size="2">Originally posted by FormulaJoe:
</font>
Yes, he is correct, it is stock and you can order an aftermarket exhaust that will replace it with a single muffler and larger diameter pipe. They came on most, I'm pretty sure all 82-84 V-8's.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 22, 2001 | 06:20 AM
Imark's Avatar
Great! at least it's replacable. It has good sound now and from what I can tell decent flow but I was looking for a little bit louder and of course better flow.
Since this setup seems kinda unusual, should I just look at a cat-back system or just replace the mufflers. a weekend bolt-on would be a whole lit nicer than a trip to the muffler shop.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
