Hooker and other header choices
OK guys, I need to start planning on an exhaust for my 84Z before I get the motor ready, so I started looking through my Summit last night. Now, I saw the Hooker Super Comp (shorties) in the upper $300 range that came with a Y-pipe. Right now, that sounds pretty good.
But, I also saw the Hooker Competition shorties for $139, and I'm assuming this is without a Y-Pipe. Does Hooker make a Y-Pipe for the Comp header? I'm not too worried about it hooking up to my stock exhaust, because that's going off soon.
Also, what about the full lengths? From what I hear, they compromise ground clearance a little bit too much, and since mine will eventually be lowered 1"-1.5", I don't want the headers scraping on every little bump.
Also, what do you suggest for an exhaust? I was thinking about the 3" Flowmaster system, but I'd like to go with something a little bit bigger. The motor out of my truck (which will soon be in the Camaro), likes to rev up to about 6000-6200, and I think the 3" will just be a little bit small. What do you think about the Mufflex 4"?
Anyway, I know that was a lot of questions... Thanks
-Joel Likness
- 84 Z28 In Progress
Road Racer
- 85 S10 350/350
Drag Racer
- 85 Nissan 200SX (yes, it's Japanese)
Circle Track Car
- 91 Lumina 3.1 Euro
Daily Driver
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
Transmission: 4L80E/4L80E
I asked Hooker about the seperate y-pipe, they said no.
I haven't checked for over a month, but last I checked the Hooker shorties w/y-pipe were $349.99 from Summit. With their handling fee, that's less than $360.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Yeah, I'm thinking that the SuperComps are the way to go. I've had enough with cheap headers. The hedmans on my truck are leaking out of everywhere, I know that hedmans would be a lot cheaper than the Hookers, but they're also built a lot cheaper. I think I'm going with Hookers when the time comes, and then maybe a Mufflex 4" Catback...
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
