question with the transfer of flowmaster
Old Mar 29, 2001 | 10:19 PM
84,86,88Z28's Avatar
hi, i just got a used flowmaster from a 96 z28 camaro,and was wondering what i have to do to mount on to my 84 z28, or do i need to do any thing at all besides mounting it? thanks
Old Mar 31, 2001 | 12:45 AM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I'm pretty sure that will not be a direct fit. I would check to see how well your peices line up with the original system. You will need to look for the hangers and any other supports and compare those to the new unit. They could be totally different. Also, look at where the Cat would meet the system. I'm not sure how the cat is situated on the newer Z's, but if it is different than yours, you are going to probably need to do some fabricating. The best I can say is make sure you are 100% positive it will work before you cut anything. Good luck.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Old Mar 31, 2001 | 01:10 PM
98_1LE's Avatar
Is it just the muffler or the whole catback? The muffler is the same, the intrermediate pipe is different. Any muffle shop should be able to make it work pretty reasonably.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Vintageracer
Jan 10, 2020 05:33 PM
Navy8125
Aug 25, 2015 08:25 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
midias
Aug 22, 2015 01:42 AM
redmaroz
Aug 16, 2015 11:40 PM
