Cat removal, what to do with O2 sensor?
Old Mar 27, 2001 | 05:25 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
Subject speaks for itself.
91 RS
Black w/ red tweed
t-tops
14x3 Open Element
80 Series Flowmaster
350TPI or Buick Turbo6 swap this summer
88 GTA
Red with grey cloth
K&N Filters
TPIS Airfoil
Old Mar 27, 2001 | 05:42 PM
idrag2's Avatar
Hey whats up..........
Summit or Jegs makes a o2 relocater kit. All it is, is a nut that you weld to your pipe to screw your o2 sen. into. It don't matter where its at just as long as it on the Pipe itself. Hope I helped
I DRAG 2
Old Mar 28, 2001 | 10:27 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The O2 sensor isnt a part of the cat, why should it matter?
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 28, 2001 | 10:36 PM
BigChevy342's Avatar
Thats what im saying, are you talking about taking off the manifold or what?
Old Mar 29, 2001 | 03:48 PM
Some muffler shop guy told me that you cant remove the cat because the o2 sensor is on it. That didn't sound right to me either. Figures, this is the same guy who screwed up my exhaust in the first place. Never go to the Midas in Albany Ga.
91 RS
Black w/ red tweed
t-tops
14x3 Open Element
88 GTA
Red with grey cloth
K&N Filters
TPIS Airfoil
Old Mar 29, 2001 | 04:23 PM
84CAMAROHIGHOUTPUT's Avatar
maybe the a.i.r tube is in the cat but i haven't seen an 02 sensor in any other place than the exhaust manifold in either of my camaros
Old Mar 29, 2001 | 06:37 PM
86Trans Am's Avatar
yea its the air tube, the o2 sensor is on the manifold, just tell him to pull the tube off, although it may take alittle work. and then considering he works at an exhaust shop ask him if he has clue
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Mar 30, 2001 | 09:39 AM
BLUE92RS's Avatar
Don't have a shop do it take it off yourself its simple. Just get a some pipe and pipe connecters and clamp it on.
Old Apr 3, 2001 | 12:35 PM
Chris 611's Avatar
All O2 sensors I have seen are mounted either on the header or just after the exhaust manifold. When I had my truck (Chevy with a 350) done, I was told you have to be careful removing the CAT because it changes the amount of oxygen in the exhaust pipes between the engine and the CAT and the O2 sensor will notice this and try to change the air/fuel mixture to compensate an they the engine will not have the correct AF mixture. This is just what I was told, don't know if its the truth or not. Hope this help.
92firebirdguy
Sep 1, 2016 07:53 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Eric-86sc
Sep 7, 2015 02:10 PM
