SLP headers installed, its really loud!
Old Apr 9, 2001 | 09:00 PM
Casey'91Z28's Avatar
Now that I put my headers on and the universal 3" cat from catco my car is really loud. It is this normal? It is almost as loud as it was when I ran open headers. Is there something I should check, I already retightened the header bolts. I think there might be holes where the cat is welded in but very small holes. Please give me some suggestions.
'91 Z28 305, Auto trans, K&N filters, TPIS air foil, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, 14.7@ 93 mph.
Old Apr 10, 2001 | 07:40 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
Headers will always be louder than stock manifolds. A high-flow cat like your Catco will not muffle the sound significantly. Make sure there are NO exhaust leaks, especially around the cat. I had an exhaust leak (where the cats are supposed to be) and tried to kill myself and two of my friends with Carbon Monoxide on a trip to Florida and back. Not good. "I'm kinda tired," "I have a headache," "Rooaddds, rooods, rrrroad." It will also keep your car from backfiring on decelleration. I bet that hooker cat-back sounds sweet with those new headers.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Apr 10, 2001 | 12:30 PM
mcconahay37's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 3RDGENFRANK:
</font>
LOL. That's a great movie.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
db057
Aug 22, 2015 08:17 PM
drathaar907
Aug 6, 2015 04:20 PM
