Can't tighten Header bolt !!!
Old Apr 10, 2001 | 07:41 PM
KW87GTA's Avatar
I have a set of Edlebrock TES on my car, and I was never able to tighten down the back bolt on the passenger side. I really want to get it tight, cause I have a little oil leak and am afraid oil might get into the exhaust. Has anyone put these in and had this problem, if so how did you get to it ?? HELP PLEASE!
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old Apr 10, 2001 | 10:45 PM
CamaroMike's Avatar
Get the bolt from underneath the header and use a 5/16" wrech flipped over. Just reach right under the header from the front of the passenger side if you don't have passenger side A/C. Takes patience but it can be done.
P.S. Get a stubby wrench if you have mega mega trouble.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Recently Ported Heads, Installed Larger Race-Flo Valves and RPM Air Gap Intake (No new times)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
[This message has been edited by CamaroMike (edited April 10, 2001).]
Old Apr 11, 2001 | 04:29 PM
Todds1987iroc's Avatar
I tightened my from underneath the car but was easy to get at because I had the transmission and starter out. I still think you can get it from the bottom. You might have to remove the starter to get your hand up in there. Good luck!
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
