manifold bolts
Old Apr 14, 2001 | 10:13 PM
89FormulaL98's Avatar
manifold bolts
my friend just brought this up....
on his '87 TA he had problems getting the bolts that hold the exaust manifold on.
i was woundering if this is a very common problem and if so there must be a simple way to deal with it.
Old Apr 14, 2001 | 10:59 PM
Dan87IROC-Z's Avatar
They do have small tabs on the bolts on some cars, mine did, so you have to bend those back before you can get a good grip on the bolts to loosen them. Otherwise you just have to use any wrenchs and swivils you can to reach the bolts. I do know that a lot are easier to reach from under the car. Good Luck!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Apr 15, 2001 | 03:05 PM
the bolts aren't typically rusted and curroded to the point where its extremely hard to remove them?
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
