HELP PLEASE! ($*#@)...
Old Apr 17, 2001 | 09:36 PM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
I was removing the a.i.r. tubes from the passenger side exhaust manifold. The reason I am doing this is because I am going to take off my cat when I get my exhaust work done. I already took off the drivers side tubes and plugged them with brass plugs. I also removed the other three on the passenger side. The very back bolt that holds in the tube is not coming out. I have been spraying it with wd-40 and other loosening solutions. It has been sitting for three days and is not budging. Tonight I tried heating it with a pencil blow torch, but that didn't seem to help me out. I really need to get this done soon. Any help/suggestions or words of encouragment are appreciated.
Thankyou,
Twells
1992 R.S. 25th Anniversary
* Borla
* Open Element
* Hypertech Chip
* Smog pump delete
Thats all for now!!
Old Apr 18, 2001 | 07:40 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Hey twells, have you visited the Kansas f-body page?? We have our own board, maybe someone can answer over there. Here's the link www.KSFBA.org . When you register and make a post be sure to let them know that SLUSH92RS pointed you over there. I've got full length headers so i didn't have to deal with that problem.
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.679
Steve Spohn
Rear Suspension
Autometer guages
Extremely Loud Stereo !
Driven Daily
installed motor with AFR's and my Hooker L/T's
Kansas F-Body Association Member
Old Apr 18, 2001 | 09:58 PM
86Trans Am's Avatar
If you are talking about he bolt holding the bracket to the block, mine was also impossible to get off, so i just cut the bracket holding the air tube to the block off with a dremel and then pulled those miserable tubes out from behind the block, it wasnt fun.
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
383backinblack
Oct 14, 2015 08:50 PM
gta892000
Sep 16, 2015 12:40 AM
