Is this good enough for a exhaust????????
Old Dec 30, 2002 | 11:26 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
I saw some flexable exhaust hose at autozone it says its good to 1050 degres is that good enough to put in place of the cat in stead of a exhaust pipe????????
Old Dec 30, 2002 | 11:44 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
opps....
Old Dec 30, 2002 | 11:47 PM
Car: 88 Camaro SC
Engine: SFI'd 350
why that flexible stuff? Just use a straight section of pipe in place of it. Its easy to install and you dont have to worry about breakage with a pipe. The cat also serves as a structural member of the exaust pipe so anything flexible will allow the exaust to move around with respect to the y pipe. Since everything is on rubber mounts, the whole exaust is designed to move as a contingous unit.
Old Dec 30, 2002 | 11:51 PM
tbfirebird's Avatar
Engine: ??????????
just i think alot easier than having to buy 2 or 3 different pipe parts.
Old Dec 30, 2002 | 11:58 PM
Car: 88 Camaro SC
Engine: SFI'd 350
id stick with the solid section of pipe to be safe... I was using a section of pipe teperarily and the pipe came off and the whole exuast past the cat was dragging on the ground. There isnt enough support without a sectiuon of exaust pipe there. The only thing i had to get was a pipe with a slip on section with an inerr diameter equal to that of the cat and a slip on connector with some clamps. Cost < $15
Old Dec 31, 2002 | 02:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Probably a reason why you don't see that done much.... One thing that comes to mind, is how durable is it?
Old Dec 31, 2002 | 09:30 PM
ddamm's Avatar
All those flexable hoses were ever made to be is temperary fix for a rotting exhaust and nothing more.
It wont last and you'll be replaceing it in 4 months IF your lucky.
Just buy a peace of pipe and 2 clamps you'll be much happier.
Old Dec 31, 2002 | 10:24 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by ddamm
Just buy a peace..pipe and..be much happier.
Seriously though.. the biggest drawback I've heard about the flex pipe is it's severly prone to leaking... i.e. one big piece of leaky pipe.
Old Jan 1, 2003 | 11:33 AM
tbfirebird's Avatar
Engine: ??????????
who ever closes threads can close this im done i just got a 2 foot pipe with flanges on one end. Sounds sweet
Old Jan 1, 2003 | 01:16 PM
ddamm's Avatar
Smart move. Those flexable pipes are useless.
Old Jan 1, 2003 | 04:35 PM
tbfirebird's Avatar
Engine: ??????????
now i need to take it to a grage to get it leak proof probally no more than $40 dollars(i hope).
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
