What exactly is the difference?
Old Jan 1, 2003 | 11:52 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
So whats the difference between a stock 3" exhaust and a "cat back" exhaust?
Yeah, my car still has the stock exhaust manifolds but I after the Y pipe I have stock 3" pipin going all the way except when it gets to my muffler...
I dont know, but how much of a difference does the so called "cat back" really do? Now I know headers will but Im asking about the exhaust....
thanks guys
Old Jan 1, 2003 | 12:12 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Stock exhaust is 2 3/4", not 3". Also its not mandrel-bent, so there are crimps and stretches in it at the bends. That disturbs the airflow and creates turbulence. Mandrel-bending is a process that keeps the bends straight, reducing the turbulence that costs power. If you look at the bends on your stock pipe now, especially where it goes over the axle, you'll see what I mean. Also, the aftermarket cat-back exhausts are a true 3" in diameter, so the extra volume helps too.
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
