Code 32 w/ gutted cat and cutout
Old Jan 1, 2003 | 11:52 AM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
Well, recently after I gutted my cat and put my cut out on, I started to get a code 32 while going down the highway. It only happens when I go down the highway and after about 5 minutes of driving. Every once in a while, it will shut off after about 15 minutes or so. Does or did anyone else havethis problem? If so, what do I need to do to fix it?
Old Jan 1, 2003 | 12:09 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The EGR valve on the TBI engine requires backpressure to get it to function properly. By removing your cat, you have removed the backpressure, and so the Code 32 EGR malfunction is being triggerd. You need to put a cat back on your car.
Old Jan 2, 2003 | 05:08 PM
CamaroMike's Avatar
Would that be with a positive or neagtive pressure EGR valve? There are two different kinds ya know. Most likely the Code 32 is from a EGR valve with a blown diaphram. Under cruise conditions the ECM compares the MAP sensor values to EGR comand or opening rate. If there is no MAP value change when the EGR is called upon to open then "bling", nasty yellow check engine light.
Old Jan 2, 2003 | 05:24 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
since the egr is exuasting into a partial vacuum, it should still work. Check to make sure the ports arnt clogged and check the valve to see if its malfuctioning.
Old Jan 3, 2003 | 04:25 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I removed my cat and all this smog ****. I dont have any problems , maybe something else is wrong in your car.
Old Jan 6, 2003 | 09:54 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
When I got my 305 TPI IROC 2 years ago I'd get the same code under the same conditions. I had a cat., but no muffler, just a intermediate pipe over the axle to a set of stock looking dual tail pipes. Sounded great, but that code 32 after a few minutes of 65 mph travel was irritating. When that exhaust started leaking I put a new Edelbrock cat back exhaust on the car and haven't seen a SES light or code 32 since. Evidently the belief in a requirement for a certain amount of back pressure is correct.
Old Jan 6, 2003 | 10:28 PM
Black91Z28's Avatar
Car: 1991 Camaro z28
Engine: 350 Tpi
Transmission: 700r4 Auto
i took off my cats and i had no prob
Old Jan 21, 2003 | 03:41 PM
Da91Bird's Avatar
I'm having the same problem. I just had my heads rebuilt, had the intake power cleaned, installed a new EGR valve and Edelbrock headers, Catco cat and Dynamax cat-back. With the new EGR valve and everything installed correctly I can't see how I might actually have an EGR failure. I'd really rather not just 'live with' this problem. I mean, the car runs fine, but I don't want that light coming on all the time. Plus, a check engine light is an automatic emissions failure.
What should I do about it?
(As I'm writing this there is a commercial on the radio explaning that a check engine light is an automatic failure, what an annoying coincidence.)
Old Jan 21, 2003 | 06:30 PM
CamaroMike's Avatar
A bad MAP sensor will also cause a code 32! Oh and about the check engine light at emissions testing. Just pull out the bulb for a day or two.
Old Jan 22, 2003 | 12:23 AM
305iroc's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.42's
I have the same problem. 3" flowmaster cat back no cat. I belive it's caused by low back pressure. I know a few people with the same problem after exhaust mods.
Old Jan 24, 2003 | 09:12 PM
godsapprentice's Avatar
Similar problem
I had a similar problem with my 2.8 camaro. Doing a thorough throttle body cleaning would make it go away for a week or two. I've read somewhere that TPI motors especially are bad about the EGR passages becoming blocked.
I replaced the 2.8 with a 3.4 using the same externals including the gutted cat and original exhaust. The light has never come on again. Leads me to suspect that there might have been something with the motor's passages.
Old Jan 25, 2003 | 04:00 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
My brother has the same exact problem with his '88. He got headers, free flow cat, and a Gale-Banks 3" cat back exhaust... and then he got the code 32. I'd say live with it, or remove the ses light.
Old Jan 29, 2003 | 05:04 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I have the same problem, one way to fool the computer is to vary your speed for 10 or so minutes, the computer doesn't change loops for a while, and when it does, it usually doesn't give you and SES code.
the only sure fire way is to have a custom chip that skips the check for code 32.
Vic
Old Jan 30, 2003 | 10:14 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Why would the engine need backpressure?
Old Jan 30, 2003 | 12:25 PM
1MEAN92RS's Avatar
Engine: LO3
The engine doesn't need backpressure...
There are 2 types of EGR systems. Positive and negative. One type (whichever we have) requires a certain amount of backpressure to function correctly. Most people either deal with the SES light or disable the EGR function in the PROM since our EGR doesn't work with high flow exhaust systems anyway.
chazman
Aug 28, 2018 03:25 PM
92firebirdguy
Sep 1, 2016 07:53 AM
racereese
Oct 3, 2015 03:46 PM
chazman
Aug 22, 2015 02:01 PM
