4 inches
Old Jan 3, 2003 | 10:01 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
4 inches
Does anyone have 4 inch exhaust over the axle? I will...but would appreciate any pictures or horror stories. My Friend does trick exhaust, chassis,,,,well he pretty much does anything custom on cars. He says this should be possible. I 'm running Hooker Super Comp headers to dual 3 inch, then y-pipe into 4 inch over the axle into a Flowmaster 4inch Delta flow Race muffler and out to one 4inch tail pipe.....We 'll See?!?!?
Old Jan 3, 2003 | 10:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just wondering why not just run one single pipe all the way back. I know the benefits of dual exhaust, but you're exhaust is only as strong as the weakest point.
Just wondering if it really makes sense to run duals into a single exhaust?
Old Jan 4, 2003 | 01:26 AM
Momar's Avatar
Mark, it doesnt sound to me like he is really making what would be considered a dual system, he just used the term for before the merging of the y pipe. It sounds about like the mufflex setup, just custom made instead.
Ben
Old Jan 4, 2003 | 07:46 AM
Car: 99 Formula
Axle/Gears: 342
Ben
Yes I understand, it's not true duals, but what I was referring to was the fact that he did have two pipes running into one. At one point in the exhaust he has dual pipes, but then it just goes into one, seems to be defeating the purpose of having 2 pipes.
Old Jan 5, 2003 | 12:18 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
He has two pipes at one point, but they are the pipes coming from each side of the engine.
Old Jan 5, 2003 | 02:17 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
DUALS?
I have full length headers so I have to start with 2 pipes. When you get to the axle there isn't any room to bring them over which is why i'm jumping to a 4 inch pipe. A single 4 inch pipe has NEARLY the same volume as dual 3 inch and on these cars where exhaust was an afterthought its the best way I have come up with to get the exhaust out the back.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
