smoke comin out my exuast, y???
i got dark blue or light blue smoke comin out my exuast, i have new tail pipes,muffler,and cat, what could this bee? im puzzeled o yeh and i have 4 days til i have to get inspection. does any 1 know what i can do? thanx for the help if any 1 replies
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
the valve seals could be bad, or you might be burning a little anti-freeze i don't really know i had that problem myself when i first got the car
91 firebird vert
tan top&interior
305/700r4<A HREF="http://www.fbody.com/members/305inmybird/index.htm" TARGET=_blank>WEB SITE HERE
</A>
91 firebird vert
tan top&interior
</A>
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Blue smoke is usually oil.
If you get a cloud of it when you first start the car it's likely that the valve guides are worn.
If it blows smoke when it's idling or when you're just driving along the whole motor is probably worn and if your 83 has the original mill in it that may well be the case.
I have an 83 TA LG4 with about 100k miles. The emissions standards for an 83 aren't that strict. Mine smokes a lot and got a conditional pass. We think the EGR is plugged and that caused the problem.
Before they do the test take the car out and run it hard. When they do the test make sure the motor is still hot.
I've been told that it helps to run some (Sunoco??) 10% alcohol/gas mix through it for about a week before the test. (or was that methanol/gas ??) Anyway, you can buy the stuff at a gas station.
[This message has been edited by George (edited April 30, 2001).]
