Problem w/ fitting of Headers to Y-Pipe
Old Jan 5, 2003 | 07:35 PM
BowtieFever's Avatar
I have the Ceramic Coated Flowtech Headers and Y-Pipe. I cannot hookup the Y-Pipe to the collectors b/c there are obstructions in the way. The driver's-side pipe will run right into the oil pan and the passenger side does not line up with the cat. There are 3 tac welds holding the mount on the collector. Can I break the welds and spin the mount around. That way everything will line up, just the pipe seems alittle too long (Perhaps I need to cut off some of the end). Does anyone have this experience with flowtechs. Also, the Y-Pipe and the Cat are the Exact same diameter.......talk about sh!tty crap?!
Old Jan 6, 2003 | 08:25 AM
primer84z's Avatar
are you saying the y pipe is already welded? mine came in two pieces. i just bolted them up slid the parts together and drove to a muffler shop to get the welds made. did you have it welded before you got it on the car? if you did, you probably just didnt have the two pieces twisted the right way.
Old Jan 6, 2003 | 11:28 AM
Sorry, if my post was confusing. But, the Y-Pipe pieces are not welded. The mount on the end of the header collector is tac welded. To line up the header and y-pipes......it is WAY OFF. But, I think it will work if the mount on the header, can spin around the collector. I was pretty sure some other headers came this way.
Old Jan 6, 2003 | 11:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The flanges on mine were at the wrong angle too.
Old Jan 6, 2003 | 05:30 PM
Attention: Apeiron
So, are you saying what I suggested.....can be done?
TX-SleeperC5
Feb 24, 2016 01:34 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
92camaro350cci
Oct 14, 2015 09:29 AM
reactor60
Sep 22, 2015 01:44 PM
BLK87Z
Sep 18, 2015 11:29 PM
