Cutout Placement
Old Jan 7, 2003 | 09:32 PM
Rhoadster01's Avatar
Cutout Placement
I recently ordered an electric exhaust cutout and had a question about its placement. I originally planned on dropping my cat out and welding a pipe in with the cutout in its place directly after the Y-pipe. However, i was told that this may cause the car to bog down and lose low end power? Is this the case and would i be better off placing it further down the I pipe towards the muffler? thanks
Donnie
Old Jan 7, 2003 | 11:36 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
mine is where the cat used to be it really isn't going to matter where you put it (as far as power is concerned) if it is between the y-pipe and the muffler, I put it so that the cut out portion faced straight back, instead of slanted to the side
Old Jan 8, 2003 | 10:35 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I have my cutout in place of my cat and felt no difference between the two. The car will be louder the closer the cutout is the the manifolds/headers.
Old Jan 8, 2003 | 10:44 PM
BRIrocZ's Avatar
Car: 97 Z28
Transmission: A4
I used to have my cutout on the I-pipe just before it goes over the axel. Made absolutely no difference whatsoever, no improvement in ET or MPH. Loud as hell though.
86White_T/A305
Mar 6, 2016 01:48 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
formula_novice
Sep 5, 2015 03:58 AM
ken3983
Aug 23, 2015 07:31 PM
Josh 91RS
Jan 22, 2001 01:23 PM
