exaust flame shooters
Old May 10, 2001 | 10:46 PM
firbird's Avatar
is it true that the flames that it makes can go back into you muffler and blow it up like some earlier reply said on flame shooters?
Old May 10, 2001 | 11:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Anything's possible.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 11, 2001 | 04:02 AM
Tas's Avatar
Tas
you're not supposed to have a muffler with flame shooter exaust. You run straight pipes all the way with the car running super rich and sparkplugs near the exaust tips. Or you can run propane or something to the tip for fuel but that seems like cheating
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 11, 2001 | 11:26 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
My friend's rustang at high rpm's will sometimes go "pop" and if your behind him at night, you can see a spark from his tailpipe, and he's got no plugs or anything back there.
Old May 12, 2001 | 01:50 AM
Joe's Avatar
Joe
A friend of the family has flamethrowers on his 52 merc it works by have a set of spark plugs in the exhaust and use a manual choke and a switch hooked up to the coil you pull the choke out which floods the engine makeing fuel go into the exhaust then you hit the switch which will turn on the extra plugs there are new stand alone systems you mount in the trunk with a battery and a fuel nozel mounted in the exhaust pipe. This guy has won 3 flam e throwing contests
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
2012sergen11
Oct 13, 2015 07:38 PM
Hello, Michael
Sep 11, 2015 01:10 PM
buckshot63
Sep 10, 2015 09:15 AM
