"off road pipe" how to get one?
I want to get a pipe to put inplace of my cat. What or where did everbody get theres? I would like to be able to put the stock cat back on when emissions come around. thanks!
92 Firebird
305TBI, Edl.Tbi Perf.Manifold, Full exhaust, air intake, 16" wheels, Tbi spacer
92 Firebird
I got my off road pipe from Mac. I think there website is macperformance.com Good luck and this will make your exhaust very loud.
88 IROC-Z 305 TPI 5 speed
Performance Resource Chip, Flowmaster American Thunder cat back exhaust, B&M Ripper shifter, MSD coil, TB bypass, TPIS MAT relocation kit , TPIS 170* t-stat, Richmond 3.73 gears, March Power & Amp pullies, Home made Ram Air, Steve Spohn SFC's, LCA's , Panhard bar, TPIS AFPR, Ported plenum by Daniel Burk, Gutted cat
Best et: 14.232
Best mph: 97.76
Best 60': 2.063
http://hometown.aol.com/famioso15/johnnyiroc.html
Best et: 14.232
Best mph: 97.76
Best 60': 2.063
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Most will require a custom pipe be made. If you are lucky enough to get headers from a company that also makes an off-raod pipe, you're in luck. MAC has off-road pipes for thirdgens, but they are pricey. You can also contact some aftermarket online vendors (musclemotors.com).
Here is the MAC OR pipe, I have one on my 4th gen (for a 4th gen), but my 3rd gen will be a custom piece.
George P. Lara
3rd Gen, 4th Gen
SCCA, SCFB, SC3GFB
George P. Lara
3rd Gen, 4th Gen
SCCA, SCFB, SC3GFB
I made my own off-road pipe. I wanted a slip-over on both sides so I could just clamp it on. What I did was bought a set of 18in Hooker slip on header collector extensions (P#520-11330 from JEGs), then cut the slip over area off one and welded it on the other. Viola, slip over on both sides, works excellent and costed $40.
'89 Firebird Formula 350
L98, WS6, Red/grey, t-tops, and a 3.27:1 rear
K&N, TB bypass, no MAF screens, CAI, full Accel ignition, no cats, Hooker Supercomp shorties, Hooker 3-inch catback
ET? The POS runs 15s.
Also own '83 Firebird 2.8 2bbl. 155K miles.
ET? Break out the calendar!
