Are my converters still good?
Old May 20, 2001 | 02:17 PM
Raymond 5.7 89 Formula's Avatar
I have 40,000 miles on my original converters how do I tell if they are still good? I have to get smogged soon so if it passes does that mean they are okay. Is it possible to have clean emissions but the cats still not giving best perfomance? Thanks for any info.
SLP 1 5/8 Headers,ATR catback exhaust,SLP cold air box,Crane 1:6 roller rockers,Bosch plugs and MSD wires,MSD Coil,Fastchip,Borg Warner 9 bolt 3:27,Corvette Servo,ROH ZS 17X9.5 Goodyear GSC,s 275/40/17
Old May 21, 2001 | 01:26 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
Yah you can pass a smog test.I just built an engine put the old exaust back on and when I rev the car pieces of the cat fall out of the tail pipe and it still past the smog test easily.unless you have an old engine or problems with your fuel injection system you should pass.My CO-% was .36, HC-ppm was 24, and the NO-ppm was 229.check out my engine combo on my web site.link down below.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
