plug probs w/ SLP headers and 6085 edelbrock heads?
Old May 20, 2001 | 05:06 PM
james_fearn's Avatar
I know some of the people are running this combo and can give a little insight. Was there any problems using 1 5/8 SLP headers and the edelbrock 6085 heads, namely the fitament of the spark plugs?
what brand of plug number did you use?
James
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
Old May 21, 2001 | 12:54 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I'd call Edelbrock and get their recommedation for which plug to use and fill them in on your headers too.
I have a similiar problem with my car. Hooker SC/LT headers and AFR heads. #7 plug won't go in, too long.
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
[This message has been edited by Phil87IROC (edited May 21, 2001).]
Old May 22, 2001 | 07:43 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I ran 1 3/4" SLP headers with the 6085 heads last year....no plug problems at all.....plenty of clearance
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Shane87irocz
Sep 22, 2015 06:21 PM
