Where can I buy a cut-out?
Old Jan 13, 2003 | 03:17 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
where can I buy a cut out? are there any that can be adjusted from inside the car? Also, is it bad to have almost no backpressure when it is opened? Thanks
Old Jan 13, 2003 | 10:42 PM
Chrome.45's Avatar
http://www.quicktimeperformance.com/qtec.htm
hope this helps
from what ive heard its nice
Old Jan 13, 2003 | 11:40 PM
BadIroc's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 Crate Motor Holley Stealth Ram
Transmission: WC T-5
you still have some back pressure when you run open with a cut out, but it depends where its located. If its located on your I-pipe the you still have some backpressure although if its located before that car after the Y-pipe and headers then you wont have as much. Its not a bad thing to run a cut-out open for a long people of time like a week or so, id used to go weeks up toa month with an open exhaust and it was fine jus dont go too long expecially if you decide to have it welded before the cat. check out summit racing, they sell the flowtechs for around 60 bucks, there the ones where you have to crawl under the car and take the 3 butterfly wing nuts off to open it but its only takes about a minute or so and those are the better kinds, plus they come in a pair so if u have a friend with an f-body too you guys can both split the cost and buy one
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
