True duals with SFC'S
Old May 23, 2001 | 02:23 PM
RyanSS's Avatar
I am planning true duals and i will need SFC's(i have t-tops) in the future and want to know if they are compatible.
I have hooker super comp LT's and will put a 3" cut out behind each collector, from there run dual 3" pipe back to dual magnaflow's underneath where back seat floorboard would normally be (gettin custom floorpan for clearance).
I will also get a new torque arm to go with the SFC's(brands unknown, suggestions?) will these create any problems with clearance?(already lost 1 1/2" - 2" with the hookers)
89 RS (supposed 350) TBI auto
Old May 23, 2001 | 07:40 PM
RyanSS's Avatar
C'mon guys. somebody has to know this.
Old May 23, 2001 | 10:28 PM
Tas's Avatar
Tas
I would think SFC would be a great idea with true duals. If you get boxed ones the weld along their entire length, you can reroute all the sensitive lines next to them and out of the transmission tunnel. This is just my idea though I dunno if its praticle or not.
I would think dual 3" is too much for a TBI 350 unless you really spin it to hell. Maybe you should look into dual 2.5". Magnaflows are also stright through so they would flow more than a similarly piped chambered muffler.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 25, 2001 | 11:16 AM
RyanSS's Avatar
The only reason i was gonna go with 3" is that i will upgrade to a 400 or 406 after not too long and don't want the exhaust to be a restriction.
How much ground clearance would i lose with something like that?
Anybody on here running this combo?
Old May 27, 2001 | 08:59 PM
RyanSS's Avatar
Anybody?
Old May 27, 2001 | 09:55 PM
SUPER-SPORT-CHEVY's Avatar
3inch kinda borders in the scrape zone unless you getto modify your floorboard "IE, BFH".
2.5 should provide plenty of flow for 400+cu monster. Another plus to running 2.5 is the clarance with the suspention on the rear end you know the bars that >< on each side, unless you plan on dumping before the rear you migh squish the pipe on a good launch.
SSC
Old May 28, 2001 | 11:52 AM
RyanSS's Avatar
thanx for the replies, but no one seems to know if true duals fit with SFC's. ?
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
