is my exhaust big enough for my new engine?
Old Jun 4, 2001 | 10:01 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
check my sig for my mods, right now I have dynomax 1 5/8" shortie headers and 2.5" single pipe into a 3chamber
which was all put in back when I had a 305.
is it still sufficient for my new 350?
I need to get my exhaust fixed as part of the pipe is caved in when I put in the new engine and tranny. should I get 3" single and larger headers? long tube headers maybe?
or simply get the pipe fixed and call it good..
Old Jun 4, 2001 | 10:02 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
forgot sig
WHO NEEDS VTECH, I HAVE VORTEC!!
1982 Camaro w/ mild L31
350 bored .02
stock Vortec heads, comp xtreme 262 cam
dynomax headers, accel ignition, edelbrock 750carb/rpm richmond 3.73's
14.02@104mph
one legged..
[This message has been edited by Jer82Z28 (edited June 04, 2001).]
Old Jun 4, 2001 | 10:15 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Does Dynomax make 1 5/8" primaries on their shorties? The last I knew they were 1 1/2".
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited June 04, 2001).]
Old Jun 4, 2001 | 11:29 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
well thats what I was told when I bought them from the parts man...
I'll go get my caliper
Old Jun 5, 2001 | 09:10 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
DynoMax uses 1-5/8" primaries, you're probably thinking PaceSetter. PaceSetter uses 1-1/2" primaries.
For the engine in your sig, your setup is fine. But I'd still get those dings worked out and if you want step up to a mandrel bent off the shelf 3" cat-back.
George P. Lara
1984 Z28
SCCA, SCFB, SC3GFB
Old Jun 6, 2001 | 12:38 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
lost my calipers, so im not exactly sure what size they are..
I was told 1 5/8" but it doesnt say anything on the box it came with.
I was thinking of buying a premade system that I could hang myself actually, but i'm not sure how well those things fit.
Old Jun 7, 2001 | 12:40 PM
CamaroX84's Avatar
I would go with 3" if I were you. It will flow a lot better. Just my opinion though.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
