how to stop exhaust leaks?
Car: 85 trans am
Engine: 79 4 bolt 350
i am putting flowtech headers and y pipe on my car, i am also cutting out the cat and putting in a pipe. i dont have a welder so i have to use clamps. i was wondering if they leak? is there anything i can use to seal them like liquid steel or silicon or anything? what should i do? thanks
Car: 1991 Firebird Formula
Engine: 305 TBI
Axle/Gears: 4.10
You really need to have your pipe welded. The joints will last longer without leaking. Try a muffler shop, most of them are pretty reasonable.
Good luck,
Don
Good luck,
Don
Car: 85 trans am
alright, is there any way to weld it with a hand held torch? if not how much do you think it would cost a muffler shop to install my headers and remove the cat?
Car: 99 Formula
Axle/Gears: 342
why would they leak if clamped properly? That's how I had mine with headers, stock cat-back and no cat, and never leaked.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I don't have headers on THIS car, but all the exhausts I've done in my life, I've used clamps and I never had leaks.
