Cat makein noise
Cat makein noise
my Cat is makeing some noise when it gets heated up, i have read through the other posts on this but i got a question, can this mess up my car in anyway, i have a 3.1 . Iam about to take this car on a 1300 mile trip home and cant really afford a problem
thanx in advance.
thanx in advance.
Transmission: 4L80E/4L80E
I assume the noise it is making is a rattle. If so, you may actually have the thing plug up the outlet on you as you're tripping along. That may not be very likely (it will probably just burn out), but...
Make sure you don't have something wrong with the rest of the car like a plug that isn't firing properly or a dirty injector. Then get the cat replaced; good time to get a higher-flowing unit.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
LT1Formula
Oct 8, 2015 08:34 PM
sjorgens
Oct 1, 2015 07:54 PM
