HOOKER 1 3/4 LONG TUBE x-member issue
Old Jan 21, 2003 | 01:20 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Does anyone have a problem with the crossmember beingin the way. If so,does anyone make one that can fit true dual exhaust? I have mine run under the x-member and clearance is a b%$#*. I scrape all the time. If I could only have the tubing come out straight from the headers I'd be fine. I have seen pictures of long tube exhaust having no clearance issues. Is therea x-member I am missing? I have an '82z w/ a th-400. any help would be great. Looking to put 3inch with bullets.
Old Jan 21, 2003 | 01:41 PM
IROC57TPI's Avatar
I know a shop that can custom make a crossmember for you but they are here in MI... Where are you?
I may be able to get you one made even so....
Old Jan 21, 2003 | 01:44 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
mpls, mn.
Old Jan 21, 2003 | 06:56 PM
1982chevycamaroz28's Avatar
some people notch there xmember. im goin to be doin that becuz im goin to use the mufflex y pipe and ive been told u have to do that to get it to fit with out modification.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
