hooker ?
Transmission: 4L80E/4L80E
http://www.holley.com/HiOctn/ProdLin...HHSCH/Car.html
The matrix says "Standard Transmission Column Shift - No; Standard Transmission Floor Shift - Yes". That would lead one to believe they will work with a clutch.
However, I can't say from direct experience if they will work on your paticular configuration.
FWIW, the emissions code specifically says "for off-road use only". So, if you drive them on the street, you're violating the use for which they are intended...
no green
Jan 9, 2016 09:22 PM
Chevykid810
Sep 28, 2015 12:57 PM
