please help me make this an INFORMATIVE POST!!
Old Jun 18, 2001 | 11:25 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
what does exaust really do for a stock engine besides sound good and keeping the engine cool. I'm running a stock 305 HO in a '84 Trans Am w/700r4 and 3.73 gears. I've added Headman shorty 4-1 headers , 2.5" Y-pie. 2.5" high flow cat,Borla 3" adjustable cat-back. on a bone stock engine,which delivers 190hp to the rear wheels stock. what can I expect these exaust mods to do? with the Borla plate closed?,open? is it neccessary to advance timing and use a different grade of gas to accomodate the differences in back pressure to see any benifit? thanks everyone,for yet another INFORMATIVE POST!!
Old Jun 18, 2001 | 11:32 PM
Like a ROC 89's Avatar
You will gain about 15-20hp on that engine do to the crappy manifolds and small exhaust pipes they used stock. No need for higher octane gas, but advanced timing a few degrees is not necessary but it is a free mod worth a little hp. If you do advacnce then you might want to run a little more octane to prevent knock
Old Jun 18, 2001 | 11:43 PM
Engine: 2.2
So I can rightfully claim 205-210hp!!??? your kidding me! that's awsome! what next? cam,intake? I'm gonna have to get this dynoed for rock solid proof! I didn't mention the K&N and air silencer delete, I thought the air silencer made a big difference at WOT. the K&N allows me to go months without changing the air filter.
Old Jun 19, 2001 | 01:15 AM
The stock engine did NOT produce 190HP at the rear wheels. The factory rates the horsepower at the flywheel. Probably made 160HP at rear.
Old Jun 19, 2001 | 08:52 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
This is the 4 brl right? You might have to rejet it to get some more power out of the engine. Ask the carb board, they would know. I don't know crap about carb.
Old Jun 20, 2001 | 05:39 PM
know_bull88's Avatar
hey jyd I did the same mods you have with the same car(84 Z28)almost with a rebulit carb and I pulled 173hp at the dyno. if this helps.
eightsixseven
Dec 16, 2024 01:50 PM
jhawkeye
May 25, 2022 06:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Reborn756
Sep 4, 2015 03:42 AM
Linson
Aug 21, 2015 02:12 PM
