What smog legal headers are available
Old Jun 27, 2001 | 04:16 PM
Mike-88CamaroTBI's Avatar
I won't ask
"Which header is best?" or
"What is the best cat back system?" or
any other number of dumb questions but i will ask.
What smog legal headers are available?
I know SLP makes them ...
Edelbrock makes them ..
But who else makes smog legal headers that will either bolt up to a stock Y pipe OR better yet have a high flow Y pipe available also.
I noticed that Summit sells some smog legal headers designed for Chev/GMC trucks with AIR. they are reasonable at $159 but will they work in a third gen?
So far i have definitely decided on Walker Dynomax for that quiet exhaust note that will keep the wife pleased. I have a 305 TBI that is mildly hotted up. I want a 3" system from the new 3"outlet (slip fit i believe) converter I will buy to a muffler with 3" in and 2-2.5" out.
Does Dynomax make a preconfigured cat back exhaust in that configuration?
Basically I want to get a SMOG LEGAL good flowing low cost head to tip exhaust setup for under or around $500 that will last a few years.
Please give me some input because i have not made a 3rdGen Camaro exhaust before so i have no experience to fall back on except here on the net. I am absolutely giving up my entire stock exhaust.
If I could find someone with a set of L69 stock exhaust manifolds with the AIR tubes still on them that I could pick up on the cheap...mailed to NC I might even consider trying that first.
Help
Old Jun 27, 2001 | 04:22 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
heddman headers and y-pipe from Jegs
headers $99
y-pipe $104
you can look em up on the website...
http://www.jegs.com
anyone know what brand the summit headers are... the pic they use looks like heddman...
later,
Chris
Old Jun 27, 2001 | 11:59 PM
HT 1985 IROC-Z's Avatar
I believe Summits 3rd gen headers are made by Flowtech. Not positive though, could be the Heddman shorties. They aren't smog legal though because they have no AIR fittings.
1985 Iroc-Z, 5.0 liter H.O. Hard Top!! Upgrades: Edelbrock Performer Rpm Intake, Holley 650cfm Zinc-plated carb, Flowmaster exhaust,Accel 8.5 spiral core wires, B&M Megashifter, 700-R4 w/shift kit, 3.23 posi.
Soon to have:
A paint job!!! White w/ black sripes, Headers and y-pipe and 3" I-pipe, World-Class 5-speed swap, Disc Brake Rearend from WS6 TransAm, Lots More!!!!! If the funds are available!!
Old Jun 28, 2001 | 10:07 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
No-one makes headers to bolt up to the OEM y-pipe. Doesn't really matter since all the makers of OE headers supply the coressponding y-pipe. Smog legal headers are made by:
  • SLP 1-5/8", 1-3/4"
  • Hooker 1-5/8"
  • Heddman 1-5/8"
  • DynoMax 1-5/8"
  • Edelbrock 1-5/8" (no more 1.5" and 1.63" BS )
  • PaceSetter (not truely sure) 1-1/2"
I highly recommend (since you are considering DynoMax's exhaust) that you also get their headers. Yes, their cat-back is 3" I-pipe with 3" in/ dual 2.5" out muffler.
George P. Lara
1984 Z28
2001 SS Coming Soon
SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited June 28, 2001).]
Old Jun 28, 2001 | 02:15 PM
90Iroc-Zee's Avatar
I would recommend SLP with a jet coat if you have the cash but I didn't so I got the Edelbrock TES Headers w/o coating and they added some power.
1990 G92 5spd LB9 - 3.42
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air
14.4 @ 94mph w/2.0622 60ft
Soon To Come
AFPR, Underdrive Pulleys, Short Throw Shifter, Intake, Cam
7-1 Against Rustangs = )
Old Jun 28, 2001 | 03:20 PM
Tas's Avatar
Tas
Dynomax doesn't have the 3" catback anymore for us. its a 2.5" with a 3" flange. That's what really gets people. The dynomax headers also have a small Y pipe. Dual 2.25" to single 2.5" You can put together a 3" system though if you have the part numbers. I have the I pipe numbers in my sig. the rest are easy to find. Trying to figure out the difference between my intermadiate pipe and that 2.5" one from their catback was a pain in the butt. I really don't like that its has a flat spot on the over axle part. I wouldn't get it again.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
redformula88
Oct 14, 2015 06:08 PM
racereese
Oct 10, 2015 09:39 PM
Chad Speier
Sep 24, 2015 12:32 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
