large tube headers...
Old Jul 8, 2001 | 01:56 PM
87tpi420's Avatar
hi everyone, been away from my car for a very long time. i had originally put a stroker 406 in the car with stock l98 heads. i have since put a 420 dry sump motor in my 87 camaro,brodix track 1's, a superam with 1,000 cfm tb. my problem is.... i know my tes headers are too small. what can i fit into the car. i took out my a/c box, and am now looking to remove power brake booster for a manual brake setup for more room. just dont know what i can fit in there that will flow huge air. this is no way a "street legal" car so i dont care about air tubes.
can anyone here help me?
thaks in advance
gary
Old Jul 8, 2001 | 02:55 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
SLP 1 3/4's maybe, SLP's are some of the best headers u can buy.
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old Jul 8, 2001 | 03:31 PM
Tas's Avatar
Tas
get some longtubes. or put duals behind some SLP shorties.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 8, 2001 | 04:31 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I think hooker makes some 1-3/4 longtubes you might want to look at. I think they also make 1-7/8 shorties for big block swaps so they might have them for small blocks also.
beyond those sizes I think you are looking into customs.
Old Jul 8, 2001 | 06:08 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Considering the heads you are using. And the displacment of that motor. I would second the Hooker 1 3/4 long tubes. Forget about the SLPs the small collectors will choke it.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jul 8, 2001 | 10:34 PM
RyanSS's Avatar
I have the Hooker 1 3/4 long tubes, they are great! Installation is a *****, and you lose about 1.5" or 2" ground clearance. The only thing I would change is I would have had them jet hot coated.
89 RS 350 TBI auto Hooker SC/LT headers Open element 3in K&N CVT protorque mini-starter
Daily driver 91 RS auto LO3 63k
New project- 89 Formula 350 WS6
383 or 400 to come!
Old Jul 9, 2001 | 10:50 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Hooker 1 3/4" long tubes are the only way to go if you have a big inch motor. Don't waste your time with the 1 3/4" SLP's. Like stated above....the install is not all that fun...lots of monkeying around with other items to get enough clearance and you do lose the ground clearance a bit. I have a Moroso 6 qt. pan on my motor and the collectors sit 1 inch below it.
gixxer92
May 18, 2017 11:20 AM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
no green
Jan 9, 2016 09:22 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
FormulasOnly
Oct 2, 2015 05:52 PM
