why is it smoking?
Old Feb 2, 2003 | 03:39 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
why is it smoking?
i jsut got done with my header install and there was quite a bit of oil on the back of my engine do to a blown valve cover gasket, but anyway i started it up and the passenger side started smoking really bad and then when it warmed up the drivers side smoked a little. it smells like paint not oil so how long does it take to burn off the paint? also it was blowing white smoke out the back like crazy even after i let it run for about 5-10 minutes. its deffinately cold but the car is in a heated garage. is this normal or do i have a problem? also the carb probably need to be adjusted if that matters. i would just go out and drive it for 30 minutes or so but i need to wait till the snow lifts before it get it out. thanks
Old Feb 2, 2003 | 03:50 PM
BikertrashDude's Avatar
the smoke from under the hood is normal.
it took miine about ten mins for the smoke to clear.
but even the next day there was alittle exaust/paint smell comeing into the ca, and I had to drive with the windows down alittle.
biker
...on probation
Old Feb 2, 2003 | 03:52 PM
maybe white smoke...leak somewhere in your exaust?
how is the car running?
SES light or anything?
biker
...on probation
Old Feb 2, 2003 | 05:25 PM
bad_ta_05's Avatar
Car: 85 trans am
i dont think there is a leak anywhere unless its coming from the passenger side collector where it connects to the y pipe but i went through and tightend it down really good. car seems to be running fine, i cant drive it till the snow lifts though. it might be leaking from where the cat connects to the y pipe, the clamp i used it a little big for it.
Old Feb 2, 2003 | 05:29 PM
bad_ta_05's Avatar
Car: 85 trans am
i also forgot to add that when you shut the car off it keeps blowing a little white smoke out the back. and i used a new set of drop in manifold gaskets i had instead of the crappy flowtech header gaskets. the gaskets i used had the same size ports as the flowtechs but they were more rectangular than round, will this make any difference?
Old Feb 2, 2003 | 06:32 PM
hmm it might, I know on the heddmans the tubes are round while stock manifolds are square..........round peg, square hole
I went the $$$ way and got mr gasket copper gaskets for the headers and collectors.
biker
Old Feb 3, 2003 | 03:28 AM
rezinn's Avatar
Biker is bad, he's on probation! Don't listen to him! He's bad!
Biker...
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
