To fix a hole in exhaust pipe.....help.
Old Jul 15, 2001 | 12:01 AM
Adam89F's Avatar
Ok guys,
I have a hole about the size of pea on my drivers side exit pipe.
What can I use to fix it?
Would this JB Weld product I have heard about work?
How about fixing a slight leak around one of the muffler exits?
I had the car's exhaust looked at and while they were looking, they wiggled it so much, it developed a leak.
Help. Thanks
Old Jul 15, 2001 | 10:52 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You can usually get away with (depending on the space around the leak) buying some thin sheet metal and wrapping it around the hole. Then tighten it down with muffler clamps.
Good Luck
AJ
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old Jul 15, 2001 | 09:04 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I would buy some exhaust tape ($3), wrap it and then put a band clamp on it, won't even cost over 10 bucks, i don't think anyway.
late model 91 rs
fully loaded t-tops, red leather
paint- gm red and yellow blend (light red)
custom painted 16" Camaro rims
305 tbi 14"x3" O.E, computer chip, accel super stock plug wires
Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: a lot of "family" cars, pickups, New v-6 stang, totally killed '86 SC Camaro.
Old Jul 15, 2001 | 09:30 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
You can buy muffler repair tape, it works ok for a little while but it's ugly, if it was mine I would just go ahead and get a new system, seems like once you fix one little hole more show up soon and your exhaust ends up looking like swiss cheese.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Jul 16, 2001 | 01:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'm surprised nobody's suggested a flattened coffee can and hose clamps yet.
(I've seen this done, it's not pretty. )
Old Jul 17, 2001 | 06:04 PM
AJ_92RS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
</font>
That's pretty much what I was talking about earlier. Just scratch the hose clamp part. Use muffler clamps. Just cut a section of the coffee can out that'll wrap around the pipe. Use the circumference formula, Diam.X Pi. Just add about a 1/4" for overlap.
I dund it B4! It'll work fine for now until you get the $$$ to buy new. The time I did it, it lasted about 2 yrs.
Old Jul 17, 2001 | 06:40 PM
MouseCamaro305's Avatar
l wouldnt use exhaust tape, its ok if its your daily driver, but if you want it to look/sound decent do it the right way. if you can get a blue wrench on it, cut out a large section of the pipe and if youre any good at welding, weld in a section to replace it, you shouldn't have to replace the whole exhaust system, unless it should be replaced. patching an exhaust with exhaust tape, in my opinion, is like pouring in engine "stop leak" to fix your 350 TPI's leaky mains or something. it's sort of half assed so to speak. hope this helps a little, good luck with it.
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
mustangman65_79
Apr 14, 2017 05:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Nj1987
Aug 19, 2015 08:26 PM
