Installed 3inch, no cat, now car runs like $%^&
Old Jul 17, 2001 | 12:23 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I know this topic is kinda hot right now about running no cat. my nieghbor put on edelbrock emission headers;1 5/8 and 3 inch pipe all the way back, and 80 series flowmaster. the thing runs worse i think. it sounds really good, but didnt pick up any gains, atleast it doesnt feel like it. its a stock 305 TBI car. i think that says it all. should he put a cat on it? would that help any? it just doesnt seem to run right. thanks for any help.
Wide Open Till You See God...Then Brake
Old Jul 17, 2001 | 03:04 AM
Tas's Avatar
Tas
boost your fuel pressure.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 17, 2001 | 10:52 AM
IROC5.7TPI's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Tas:
</font>
Also make sure hes running an open element air cleaner.
Did he plug the smog tubes? Delete the AIR pump? This needs to be done if the cats gone.
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Jul 17, 2001 | 12:29 PM
IROC-Z_85's Avatar
Some peoples kids
1985 IROC-Z, nuff said :P
Old Jul 17, 2001 | 02:15 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The suggestions here are good . When you go for headers/ larger pipe it frees up the exhaust "Your saying DUH " This is only part of the equation "the most restrictive mind you" Now that the exhaust is free you can take in more air hence the "open element filter" now that you have more air you need more fuel "boost fuel pressure" now that the fuel pressure is boosted and more air can get into the combustion chambers the free flowing exhaust is needed to expel the exhaust. All of these combined make a more efficient engine, not just one. Although in some cases upgrading the exhaust helps a lot because it one of the most restrictive elements of the system.
SSC
Old Jul 17, 2001 | 10:49 PM
LilJayV10's Avatar
Engine: 406 Roller
the stock emmisons stuff is still on it, well except for the cat. the air tube that went to the converter hanging there, not hooked up to anything. i will look into boosting the fuel pressure, how much should i raise it?
Old Jul 17, 2001 | 10:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by LilJayV10:
</font>
Crimp the line it could cause a problems including backfire on deccelration.
Fuel pressure is hit or miss crank it al the way up and then back down until you get the desired amount. Im not a Fuel injection guy at least camaro wise but my blazer TBI is cranked up full blast with no problems.
SSC
onefreakz
May 14, 2018 12:15 PM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
drathaar907
Aug 6, 2015 04:20 PM
