can you take the catback out in i piece?
Old Jul 21, 2001 | 03:47 PM
firbird's Avatar
Can u take the catback out in i piece without cutting it? Because since i am broke and need a bigger catback for my 350 i put in, can i just get it off a firebird with a 3" exhaust for now?
Old Jul 21, 2001 | 03:58 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
"maybe"
You'll need a lift most likely to do it. I had my car up on jack stands and the best I could do was to hacksaw it.
Of course, if you hacksaw it, you could get it welded, or get some band clamps to put it back together, too.
--andrew
Old Jul 21, 2001 | 04:08 PM
firbird's Avatar
yea i am tring to take it off my trans am that doesnot have a engine right now and put the catback on my firebird. my firebird i really did not care about the old exhaust so i just cut it before the muffler and jacked up the back and took the braceings out of the way and pushed it forward. but how well would it work if you cut it and took it out and reconnected it with clamps on another car, just seems pretty cheep but i might have to do that.
Old Jul 21, 2001 | 06:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My catback came out of the car from which it came and went onto mine in one piece. You have to disconnect all of the rear end parts that get in its way on the right side: Lower control arm, spring, shock, panhard rod, ebrake cable. I don't have a lift, did it with jack stands in my garage.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 22, 2001 | 04:34 AM
firbird's Avatar
thanks, little bit harder than i thought it would be but nothing is really easy when you are working on you car
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
racereese
Oct 3, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
