all of those who have hooker 2055 headers, please enter
Old Feb 8, 2003 | 07:02 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
have any of you had your headers glow red hot. i started my 408 for the first time today and they were glowing red hot. i also have jet hot coating on them. i don't think this should be happening. is there something wrong?
it was running open headers. all i have is the headers and the y pipe connected. i don't know if this affects anything
Old Feb 8, 2003 | 09:53 PM
KMAN's Avatar
I dont have them but might be ordering them within the next few days. hows the fit and the install.
Old Feb 8, 2003 | 10:05 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Re: all of those who have hooker 2055 headers, please enter
Running on open headers won't affect anything at all. Just don't run them open in the cold weather because I hear you can burn a valve.
The reason why your headers are glowing red is either:
A: Your timing is severly retarded ....... or
B: Your motor is running lean
Good luck
Old Feb 9, 2003 | 09:21 AM
Car: 84 camaro Z28
Engine: 434sbc
they fit nice but it is hard as hell to chance the #5 spark plug (took me about a half hour to 45 min just to change that plug).
as for burning the valve, i heard that, that will only happen if you run it with nothing on at all. it burns the valve due to the dramatic change in temp. i have the headers and the y pipe on so i should be fine. i'm doing the timing today so i'll see what happens. thanks alot
Old Feb 9, 2003 | 09:58 AM
KMAN's Avatar
those have the air stuff, correct
Old Feb 9, 2003 | 02:57 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
yes they have the air 'stuff' on them....
I have a set of 2055's for sale if anyone's interested...still in the plastic bag from Hooker...they ARE missing the Y pipe...but a local shop could make one up for you
Old Feb 9, 2003 | 03:01 PM
Car: 84 camaro Z28
Engine: 434sbc
heres pics of mine installed
Attached Thumbnails all of those who have hooker 2055 headers, please enter-header-clearance-2.jpg
Momar's Avatar
Hey, I know what that looks like. I just started my 350 for the first time with hooker lt's and dual exhaust and I had the #7 glow red. Well, I think my problem was the valve lash wasnt correct(it was the first time I have done it). My cousin came out today and set it for me. I hope to start it up again in a little while. Did all of the primarys red or just one or 2? If it wasnt all of them which ones was it. I agree that if it was all of them it was probably either your timing or being too lean, but if it was just a certain one or something I would double check the valve lash. How did it seem to run other than that?
Ben
Old Feb 9, 2003 | 03:02 PM
Car: 84 camaro Z28
Engine: 434sbc
heres the other side
the problem was the timing. me and my dad set the timing today and it runs great. now i have to get the exhaust and subframe connectors installed. thanks
Attached Thumbnails all of those who have hooker 2055 headers, please enter-header-clearance.jpg
Old Feb 9, 2003 | 03:04 PM
justadba's Avatar
looks good heavy_chevy
Old Feb 9, 2003 | 03:12 PM
Glad to hear my idea worked.
Nice lookin ride BTW
Old Feb 9, 2003 | 03:14 PM
justadba's Avatar
starter problems with hookers..
Anyone experience any starter problems after installing 2055's? Seems mine is giving me problems...at least I think it's starter.
Had to replace alternator after the headers went in....thinking just a coincidence cause it was suspect before the headers.....
Now, seem to be having starter issues....
Voltmeter reads a constant 13 or little over volts when running. Doesn't seem to really pout on a huge charge after starting, but sometimes when starting (especially after engine hot and been running awhile), the starter will just tick, tick,tick until I make sure i have all electrical turned off and the door closed...then it seems to start a little better....
I wrapped the headers with thermo tec to where the y pipe hooks on hoping that would force some heat down the tubes....
anyone with any ideas?
Old Feb 9, 2003 | 03:26 PM
Car: 84 camaro Z28
Engine: 434sbc
summit sells heat sheild materials. that might work
Old Feb 14, 2003 | 04:32 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Heat is definetly a concern with long tubes. Notice my starter... This is fairly cheap, generic heat shield material with metal strappings ordered directly through summitracing.com. As you know, ceramic coating also helps slow heat transfer. A mini starter will also help (not necessary) due to its parts being farther away from the header.
Old Feb 16, 2003 | 04:48 PM
bigals87z28's Avatar
Car: Check The Sig
whats the part number for the hookers without the AIR tubes? i know the 2055's come witha y pipe, but the other ones dont.. the other pair is a shortie and you have to get the y pipe seperate... i dont want the air tubes there. Ill save that money for coating. good looks with the headers man... i cant wait to get everything up this spring!
ZZ3Astro
Aug 13, 2019 12:57 AM
redformula88
Oct 14, 2015 06:08 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
hdis2002
Sep 8, 2015 02:52 PM
