hooker 2055
Old Feb 8, 2003 | 08:30 PM
KMAN's Avatar
hooker 2055
does anyone have these headders? how was the install and do they have the AIR crap? thanks
Old Feb 8, 2003 | 08:50 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: hooker 2055
Yes, they have AIR from my knowledge, Five7kid suggests them all the time, I'd be inclined to go along with what he says.
Old Feb 8, 2003 | 09:30 PM
KMAN's Avatar
cool, thanks for the help. do you post on either 3go.org or nethirdgen.org i think i have seen you name elswhere?
Old Feb 9, 2003 | 08:48 AM
Car: 99 Formula
Axle/Gears: 342
nethirdgen
Old Feb 9, 2003 | 03:00 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
have them installed....
right side definitely NOT for the faint of heart to install...depending on year and equipment ...had to undo motor mount and **** the motor a little to get them in...pull AC comp. loose from motor, plugs OUT (not easy to put back in)
but absolutely worth the effort once you're done
Old Feb 9, 2003 | 06:33 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Yes they do have the emissions stuff. It is a tough install though. I installed my right header from the top but had to remove the valve cover. Tightning the bolts was the real fun part for me, but it was worth it.
David
Old Feb 9, 2003 | 06:48 PM
KMAN's Avatar
justadba, did you jack the motor up from below, and if so where did you put the jack, or did you use a lift
Old Feb 9, 2003 | 07:03 PM
justadba's Avatar
from below....put piece of 3/4 " plywood between oil pan and jack stand
car was up on a lift....
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
