Installing a Catback
Old Jul 27, 2001 | 11:47 PM
Gta-Paladin's Avatar
I purchased a Mufflex 4" And im wondering if i should attempt putting this on myself i have no experience, everything else has been done by a shop... I've got no skill... But i mean it LOOKS relatively simple... any ideas?
Old Jul 28, 2001 | 06:33 PM
87tpi420's Avatar
do you have a jack?...and aa set of 4 jack stands? basic hand tools? if so.....give it a shot...you need to start learning somewhere....why not save some money and start learning here. have a friend help you!
if you dont have any.....ask mom or dad
if there not around....hire some guy off the street to help.....yeah you will still spend money...but you will learn something in the process!! good luck
http://people.ne.mediaone.net/gdm
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Jul 28, 2001 | 07:20 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Just get some ramps, back your car up on them and go to town with a saws-all Hack the old exahust off (unless you want to keep it for some reason) and put the new one on. Its easy to fit the i-pipe if you have two people.
Chuck Kulchar
1991 RS
Open Element w/K&N
3.42 - posi - disc
3" cat and Force II cat-back
Old Jul 29, 2001 | 12:19 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I think you would be better off with jack stands then ramps, that way when the car is in the air the rear end will drop, giving you clearance to take out the muffler and exhaust pipe that runs over the rear, and will give you more room when you are putting in the exhaust that's what my brother and I are planning on doing next weekend with my exhaust.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage
"There is nothing more addicting than speed"
Old Jul 29, 2001 | 12:21 PM
Car: 99 Formula
Axle/Gears: 342
Just wondering, what kind of setup do you have to have ordered 4" exhaust, you might be overdoing it and losing some of the backpressure you need.
1984HO
Mar 19, 2021 11:59 AM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
transaero
Aug 31, 2015 01:14 AM
theurge
Aug 21, 2015 12:46 PM
