My new duals
Old Feb 9, 2003 | 09:10 PM
Momar's Avatar
My new duals
Here are a few shots of them. Clearance isnt great, but I think once I get it welded and get rid of the clamps it will be livable. Here are a few pics.
Ben
Old Feb 9, 2003 | 09:11 PM
Momar's Avatar
Old Feb 9, 2003 | 09:12 PM
Momar's Avatar
Old Feb 9, 2003 | 09:17 PM
darbleinad's Avatar
Car: 84 Trans Am
looks good. i love duals and i am very happy i went with them. those long tubes look sweet too. good work.
Old Feb 9, 2003 | 09:20 PM
Momar's Avatar
thanks
Old Feb 9, 2003 | 10:13 PM
1989RS's Avatar
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
looks really good
Old Feb 9, 2003 | 10:15 PM
1989RS's Avatar
how do they sound?
Old Feb 9, 2003 | 10:22 PM
Momar's Avatar
They sound great from what I heard, but didnt get to run them long yet. Trying to work out some problems with the motor.
Ben
Old Feb 15, 2003 | 10:51 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
were are you having ground clearance problems at? it looks like you have quite a bit unless you have the car jacked up. thanks
Old Feb 15, 2003 | 12:46 PM
Momar's Avatar
Well, I havent driven the car yet so I dont know if I will have clearance problems or not, but I believe that other than the clamps it doesnt get lower than the collector flanges. I was hoping to try to get my problem with it worked out today but we just had an ice storm yesterday and now it is snowing and I really dont want to take it outside in this cold and snowy weather to work on it. The lowest point is in the second picture though.
Ben
Old Feb 15, 2003 | 02:26 PM
LilJayV10's Avatar
Engine: 406 Roller
are those the headman s bends? did you do any other custom bends on the rest of them? looks good.
Old Feb 15, 2003 | 02:49 PM
Momar's Avatar
Yes, those are hedman s bends. They are the only bends I had to use at all, but I did have to modify the s extension on the drivers side. It turns out that the flange on my header on the drivers side doesnt aim exactly straight back. I had to cut a "pie slice" out of the side of the pipe and heat it up and bend it together and reweld it. This allowed it to aim straight back instead of ending up under the driveshaft. There are no places locally that do mandrel bending so this was the only way I could retain the diameter of the pipe and bend it. If I had them just bend it some more it would have squeezed the pipe down to probably about 1.5 inches. Here is a link to when i was first trying to figure it out. I have a diagram I made real quick on how it was lining up instead of how it should. https://www.thirdgen.org/techbb2/sho...postid=1090724
Ben
Old Feb 16, 2003 | 12:03 AM
MdFormula350's Avatar
nice looking!!
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
