Best Headers for my Car??? SLP??
Old Jul 28, 2001 | 09:28 PM
ChickMagnet89's Avatar
Is SLP the best Headders for my car...I have an 89GTA with a 350tpi, No Current Mods...yet. What Size tubes would be optimum. I'm also thinking of going with AFR 195cc Heads in the Future so I need some headers that will be compatible with those also.
Old Jul 29, 2001 | 10:31 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
SLP's are good for your engine (1 3/4), but are expensive. Check the archives for more info on this topic.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 29, 2001 | 12:15 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you have the money get the SLP's, I couldn't quite afford the over $400 at the time and got the Edelbrock, when I first put them on my 305 I definately noticed a power and sound gain. The good thing about the SLP's is they come coated, my TES headers are now rusty looking.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage
"There is nothing more addicting than speed"
Old Jul 29, 2001 | 08:45 PM
so I should get the 1 3/4 tube headers...hugh.... are those too big for a 350? or just right?
Old Jul 29, 2001 | 11:42 PM
IROC-Z_85's Avatar
I know a guy running 1 5/8 on a 383 that will revt o 7k
1 3/4 is probably a bit big for a STOCK engine
depends on if you're after torque or HP
1 3/4 for carb
1 5/8 for TPI
1985 IROC-Z
TPI 305, 700R4 with shift kit, richmond 3.73's, auburn pro series posi, crane compucam 2030, ported plenum, gutted air boxes, all the little insignificant stuff.
Old Jul 30, 2001 | 04:00 AM
90Iroc-Zee's Avatar
My friend has a 89 Iroc-Z with 1 3/4 and was VERY happy with them. 14.2 @ 98mph with a 2.1X 60 ft. 2.0 60ft and hes hitting 14 flat. That was awhile ago though, he had free mods at the time. Now he has chip and removed smog and hits 14.0, with a decent 60ft again he is all 13's with an exhaust, not to shabby with 2.77 gears. He knows lots of **** though, if i had his knowledge i wouldnt have hit a 14.4 after my header installation, stupid 5spd 2.16 60fts, they are no good in 1st gear!
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Old Jul 30, 2001 | 04:03 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, go with the SLP 1 3/4's if u can.
89 RS
STILL Looking For:
87 IROC-Z28 350 TPI
1992 Trans Am
May 10, 2023 07:19 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 7, 2015 09:55 PM
