CAn i "coat" my own headers??
is there any product they sell that i can use to spray on headers and make them "jet hot coated" per se? and are flowtech headers any good? do they come with the AIR smog attachments?
[This message has been edited by ron rizzotti (edited February 06, 2001).]
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ceramic coatings such as Jethot are baked on. Even the local shop here in Calgary won't let you see how they apply the coating because of copyrights. I know it's similar to how they do powdercoating. Electrostatic charge, spray the coating on, then bake it.
Mine are coated. Guarenteed for life that they won't chip, peal or rust. The only guarentee they won't give is if you burn them. ie. run the engine too lean.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
There's two types of ceramic header coatings for sale. Retail which air dries and shop which requires baking. Both require the use of a paint gun. A few people have bought junker ovens to bake them, since just like powder coating the over is no longer safe to cook with. Other then that, can't help you check out these sites, they sell the stuff and have some FAQs.
http://www.techlinecoatings.com/
http://www.performancecoatings.com/
1989 Camaro RS LO3 WCT5 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
The posi unit breaker.
Car: 87 IROC L98
Top Gun coatings does it here. Headers are sent from all over Alberta to them to get coated. My BBC supercomps cost $250 to get coated. I think a set of shorties is about $150 or so.
I'd get the stainless Edelbrocks from my truck done also if I had another vehicle to drive while the headers were off but that ain't going to happen
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Hi,
I have some Edelbrock 6872's which I painted with VHT1600 degree paint. First I chemically stripped them of all black preservative paint, then I painted them with the VHT, and baked them in an electric lab oven. I followed VHT recommendations and heated them with the 3-step process.
I ended up with a diamond hard finish that doesn't chip, and after one summer shows no signs of discoloration or rust.
This might be an alternative to coatings if you are simply looking for exterior appearance. There's pictures of them on my website, I believe. Oh heck, I guess I could just embed a graphic into this message for you and save you the trouble...
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Daniel Burk
Does anybody know where there is a sort of "tech article" on coating headers yourself. It looks like a great deal if you buy the supplies and coat your own. I'd just like to see some more details. Thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
