A.I.R. System
Old Aug 1, 2001 | 10:56 PM
Iroc n roll's Avatar
A.I.R. System
I just finished taking out the Smog pump and the rest of the AIR system. I capped off the AIR inlets on my headers with 1/2" pipe caps. Now I have the metal tube that used to connect the AIR inlets on the headers to the little black relay thing left over. Also I have the metal tube that goes to the Cat left over as well. Is there any way that I can get those out of there? Also, does having them there unplugged harm anything?
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, TB coolant bypass, Hurst Dual-Gate Shifter, Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Aug 1, 2001 | 11:36 PM
82resto's Avatar
If you keep those tubes on there, you have to cap them off. What i did for the tubes from the cats to the black thingee (as you so eloquently referred to it as ) was cut the pipes near the cats and place caps on them. The black thingee and the smog pump (the pump below the AC on my 89) can be removed without throwing any sort of codes.
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
Old Aug 1, 2001 | 11:45 PM
What do those tubes connect to? From what I could see one end went to the cat (which is not connected to the cat) and the other went to the black thing. the other one connected the AIR inlets on the headers to the black thing. If I'm understanding this correct I have removed everything that was connected to the tubes, so now I should just have a tube in my engine compartment. Why do I need to cap this? Do they connect to somthing else?
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Aug 2, 2001 | 12:36 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
quote... "the black thing"
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Johnny*G
Oct 20, 2015 12:37 PM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
