Hooker shortie headers... (#2055)
Old Aug 9, 2001 | 10:04 AM
Drowned's Avatar
The Hooker #2055 are shortie headers with a Y-pipe right? Who's got them and how well did they perform? How about the welds and measurements, etc...
Old Aug 9, 2001 | 10:20 AM
bklucas12's Avatar
I have them, tried installing them last week... screwed my holley fuel pump up my car wont start, there a bitch to install, I hate my life...
Old Aug 9, 2001 | 02:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have them but haven't installed yet. The flange gaskets they provided have smaller openings than my World 305 S/R ports, so I'm getting different ones. The flange welds aren't completely clean, so I'll take the die grinder to them after getting the gaskets.
The biggest surprise was the collector to y-pipe ball-joint connector. It only has a 1.9" opening, going into the 2-1/2" OD down-pipe of the y-pipe assy. Seems a larger opening would be beneficial. I planned on doing a fit check, then opening up that joint centered on the down pipe.
I wrote Hooker 2 months ago about the above issues, never heard from them. Other than that, though, they look like good pieces.
One other issue I haven't addressed yet: The A.I.R. pipe on the driver's side where the check valve connects faces back, whereas the stock (at least LG4) faces forward. Not sure how I'm going to route that. Does the LB9/TPI face towards the back? Don't recall looking at that.
I'm putting mine in when I put in the other engine, so I don't anticipate installation problems.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 12, 2001 | 02:45 PM
tacoboy's Avatar
how did you manage to screw up your fuel pump putting in headers? just curious...i have those headers, just installed them, not too bad, not a single day job for me though, but i also removed AIR at the same time...driver side header is tricky...
no green
Jan 9, 2016 09:22 PM
Johnny*G
Oct 20, 2015 12:37 PM
thekurlyone
Sep 30, 2015 12:54 PM
Zell1luk
Sep 29, 2015 10:36 AM
Night rider327
Sep 16, 2015 02:20 AM
