AIR or Not? Please read
Old Aug 11, 2001 | 08:49 PM
'88Camaro305's Avatar
Alright. I've heard all kinds of different answers to this question. If i get rid of the AIR tubes on the camaro, will it run right and pass emissions? I've heard that it will pass smog, but if a technician looks at it and sees no tubes that it will fail. the reason i ask is i don't want to spend the money for headers with air built in. Thanx.
Old Aug 12, 2001 | 03:56 AM
Omar's Avatar
If you have a visual in your area, you will fail. Pretty simple.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 12, 2001 | 12:24 PM
Rice_Cooker_'88's Avatar
But will it pass the sniffer test?
Old Aug 12, 2001 | 05:37 PM
OldBlue's Avatar
if your engine is in perfect running order it should pass. ANY engine will pass if its running right. that means its getting the right amount of fuel spark and not burning oil. a guy around here built a 454 w/o the smog junk and passed with flying colors.
Old Aug 12, 2001 | 10:02 PM
Omar's Avatar
Like Blue said, if you have a clean engine and a clean cat, you will pass without AIR.
Old Aug 12, 2001 | 10:10 PM
MikeS's Avatar
Actually, you can get by a visual inspection without it. It just depends on specifically what they look for. We have a visual and dyno emissions test here, but the visual is limited to looking for a cat and checking for a gas cap. Other than that, it's cool with them as long as it passes the sniffer. Find out what they look for in the visual and use that as a guide.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
