anyone have pics of y-pipe on longtube headers?
Old Aug 9, 2001 | 06:58 PM
Eighty5TransAm's Avatar
Topic says it all
Old Aug 10, 2001 | 08:48 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Clink the exhaust link on my webpage and you will see some pics of my exhaust set up. I have full length hedmans and a custom made y-pipe with cutouts.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Aug 10, 2001 | 04:25 PM
ya someone sent me a link to your site, what kind of ground clearance do you have near the tranny crossmember? And did you just cut an existing cat back then hookem up?
Thanks Curtis
Old Aug 11, 2001 | 06:39 PM
jbenge's Avatar
I just went out and measured my ground clearance at the crossmember, its just under 4inches. Those pics were taken before I intalled a spohn torque arm which uses a different crossmember that is lower, with a stock crossmember you would have a little more ground clearance than I currently have. And yes I just hooked up a cat back system to the y-pipe, its just a flowmaster american thunder with the dual 3in. stainless pipes out of the muffler.
M/T ET street tires
Old Aug 16, 2001 | 03:21 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
http://www.geocities.com/cfrios/Phil...l?996948051310
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
