need help installing exhaust
Old Feb 18, 2003 | 07:06 PM
akamoose's Avatar
Car: 92 RS
Engine: 3.1V6
I am replacing the exhaust on my 88 sc. What do I have to do to get the intermediate pipe out in one piece? All I can think of from looking at it and failing to remove it this afternoon, is to get the car high enough to work the pipe out. I need to get the pipe out in one piece cause obviously I'll need it in a similar position to put the new pipe in. Would it make enough difference to remove the rear braces?
Old Feb 18, 2003 | 07:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"New pipe"? What is it, exactly? Most aftermarket pipes have a joint just in front of the axle.
But, I have done this. My first exhaust was a take-off from a GTA, and was all welded together, from cat to tail pipes. Remove the right-side tire, lower control arm, shock, park brake cable, and track arm. The exhaust will all slide out with the car no more than a foot off the ground.
Old Feb 18, 2003 | 10:05 PM
akamoose's Avatar
Car: 92 RS
Engine: 3.1V6
Thanks for the tip I'll give it a try in the morning. I bought a dynomax cat-back from summit. The pipe is all one piece and bent to shape just like the stock pipe.
Old Feb 19, 2003 | 09:35 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Probably all you need to do is get the rear tires about 8" off the ground with the axle hanging (jack stands on the frame) & remove the pass side lower shock bolt with a jack under the axle & lower that side down, watching the brake hose & park brake cable that they don't stretch too far. The pipe should go over the axle then.
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
