aftermarket exhaust
Old Aug 19, 2001 | 07:00 PM
chrisandkristin's Avatar
aftermarket exhaust
i just put on edelbrock headers a random tech cat and a random tech cat back its all 3 inches i just want to no how low does it hang .right now it hangs lower than the ground effects i just want to know if that is right
Old Aug 19, 2001 | 07:52 PM
Dan87IROC-Z's Avatar
Yeah, that sounds normal, my exhaust hangs a little lower than the ground effects, especilly the I-pipe on the cat-back.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
db057
Apr 28, 2019 07:45 AM
J-money
Jan 4, 2019 09:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
