Not my Bird but I need help.
Old Aug 21, 2001 | 01:33 AM
IH8FORD's Avatar
I am trying to remove the cat off my 93 Chevy Truck (4.3 V6 Full size) and ran into some problems you guys may be able to help me with. First: I unbolted the exaust system from the cat back BUT I can't get the freaken cat off for the life of me. The tubbing from the cat slides inside my exaust tubbing and wont let go. I have banged, pulled, pryed, cussed, prayed, and yet nothing! ok Second: I figured since I can't get the cat off I will unbolt if from my headers and work from there. While atempting that I noticed springs on the bolts holding the headers to the exaust and the more I lossend the tighter the springs seemed to get. WTF is that? I didn't take them off for one I didn't know if I could get them back on with the funky springs and all. I have pulled about every muscle I can think of and ones I didn't even know I had. So if you know a trick PLEASE help me out here.
PS. I know it's not a 3rd gen but it's kind of an emergency.
Old Aug 21, 2001 | 01:53 AM
87tpi420's Avatar
did you try lube? spray some wd-40 or some penetrant in the seam. i just took my Y pipe off and and had to unbolt my cat with it and was swearin up a storm..then sprayed it and started wobbling and it slid out. if you have access...i would heat it with a torch
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Aug 21, 2001 | 02:14 AM
IH8FORD's Avatar
Yeah I lubed it down good and all it did was spit the lube in my eye It's going to be a PITA I can see that.
Old Aug 21, 2001 | 04:09 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Does the cat have a air tube going to it??
Should be a small about 1/2" tube running into the cat on the side.
If you have this tube.... it is more than likely welded to the cat.
You'll need to cut that tube to get the cat off.
Old Aug 21, 2001 | 04:34 PM
IH8FORD's Avatar
Naa, no air tube it's just the tube holding it on and it's holding it very very well.
Old Aug 22, 2001 | 03:59 AM
IH8FORD's Avatar
Come on guys someone has to know a trick. My daily driver is down.
88 Firebird Formula
350 T.P.I. (Stock unfortunately)
@$$, cash, or gas no one rides for free!
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Numbah-1
Oct 2, 2015 08:27 AM
abrilnelson89
Sep 17, 2015 10:41 AM
abrilnelson89
Sep 16, 2015 02:19 PM
