Ordered headers...what do I do with the O2 sensor?
Old Aug 25, 2001 | 10:52 AM
Golden80's Avatar
I ordered a set of Dynomax Cerama-coat headers and am wondering if I need to either drill a hole for the O2 sensor or if I need a different set of headers. I have a stock LG4 with a comp-controlled QJet.
Thanks,
Matt
Old Aug 25, 2001 | 01:38 PM
87tpi420's Avatar
if you need o2 sensor then you need to weld the little bung in place. they sell them in summit for like 12 bucks. you will have to grind them to weld in the bung so you will ruin the coating. you could put a heated 02 sensor in the Y pipe that way the headers stay coated. or you could get a set of headers with the o2 sensor fitting in them. last option is to grind and weld then send them and have them re-coated.
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Aug 25, 2001 | 02:12 PM
Golden80's Avatar
Do you know where I can get a heated O2 sensor?
Thanks,
Matt
Old Aug 25, 2001 | 11:23 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Check the footnotes on their web site. If you ordered the ones for your car, they usually come with a bung for the O2 sensor.
AJ
bryanwood74
Sep 24, 2015 09:50 PM
Randomtask2
Sep 10, 2015 08:37 AM
Tim Burgess
Oct 18, 2001 02:51 PM
L98IROCZ89
Jul 26, 2001 04:15 PM
brharris27370
Apr 30, 2001 01:18 PM
