V6 new engine problems
Old Apr 30, 2001 | 11:51 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
This is on my wifes 2.8L MPFI. Her engine died at 180k miles and she refused to let me put in a bigger motor. So I ordered a new crate 2.8L motor. Replaced all the sensors and injectors including cold start injector. Replaced thermostat hoses belts, distributor. Pretty much everything. So I finally got it all together and fired it up. I wanted to run it 30 mins at 3000rpm to make sure and break in the cam. BUT after about 5 minutes the exhaust was glowing red to the point that the antiseize compound that I used on the bolts holding y pipe to the manifolds caught on fire. So I was forced to shut her down. I though that it could be the timing or the computer just hadn't relearned the new motor yet. So I restarted the car after it had set about 10 minutes and set the timing at about 25-30 degrees (computer still controlling at this time) and retried the 3000 rpm run. Same problem. I did not have any lean running problems before the motor install. What is the problem. The computer is not throwing any codes saying that it is running too lean. I put a nice new bosch o2 sensor in it. The motor sounds great but I have to get by this exhaust glowing problem. Is my cam screwed now because I couldn't make her run 30 mins.
Old Apr 30, 2001 | 01:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did your catalytic convertor somehow get clogged up? The timing could be way out of spec, too... could you:
1. Spin the engine so the balancer mark for #1 is at 10 deg advance mark
2. Align the rotor to the cap so the rotor's aimed at the #1 plug terminal
Wouldn't that give you the 10 deg advance the motor calls for?
Don't know about the cam...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
