Off-road pipe...
Old Feb 22, 2003 | 12:19 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Off-road pipe...
I was thinking of getting an off-road pipe made for my car to replace the intermediate pipe. That way I can take off the cats at the track. I planned to have one connection right before my cut-out before the right rear tire and one after the y-pipe. The only problem I see now is how to make it so I can disconnect the AIR lines from the cat easily. Anyone have any ideas?
Old Feb 22, 2003 | 10:09 PM
trans87's Avatar
TTT
Old Feb 23, 2003 | 02:42 PM
trans87's Avatar
Guess no one has ever done this
Old Feb 24, 2003 | 01:16 PM
MelloYello's Avatar
Dont make the off-road pipe that big, just go to a single cat setup with an slp/edelbrock y-pipe and flange the cat and a similar length of 3"pipe (about 18" long). Thats what i did. The stock dual cat setup is a PITA to begin with - converting to a single cat was the best thing i ever did (especially with the test pipe in place of the cat)
Old Feb 24, 2003 | 06:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An alternative would be a cut-out in each down-pipe each about the same distance from the manifold/collector. Only down-side is you'd have to jack the car up to get to the cut-out (unless you went electric). But, you'd have to jack it up to do this "off road" pipe, anyway.
Old Feb 24, 2003 | 09:36 PM
trans87's Avatar
Yea I just wanted to flange it on so I can just unbolt the pipe with the cat and bolt in a pipe with no cat. The only problem I saw was with the air lines. How do you make those detachable?
Old Feb 24, 2003 | 11:43 PM
five7kid's Avatar
With an A.I.R. repair kit. Comes with some high-temp silicone rubber hose and clamps. I picked mine up from Checker (ain't cheap, about $20). Then, just undo the hose clamp, slide off the tube, hook up your off-road tube.
Old Feb 25, 2003 | 12:31 AM
trans87's Avatar
O cool! So I would just cut the air lines then use the AIR repair kit to attach them again? That way I just disconnect the AIR tubes by taking off the clamps and pull the lines out of the rubber connector?
Old Feb 25, 2003 | 10:21 AM
five7kid's Avatar
Yep.
Old Feb 25, 2003 | 10:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you do that, do you need to worry about blocking off the air tube where you disconnect, or is it ok to run with it just hanging out there?
Old Feb 26, 2003 | 09:55 PM
trans87's Avatar
It will be fine just hanging there, I will disconnect the belt for the smog pump
lonsal
Aftermarket Product Review
Jul 21, 2002 05:48 PM
84berlinettaV6
May 28, 2002 07:37 PM
Macgyver
Jun 16, 2001 12:02 PM
