Question on catalytic converter
Old Sep 1, 2001 | 10:02 PM
Golden80's Avatar
My stock converter doesn't have a hose coming out of it. The smog pump pushes directly into the exhaust manifolds. I got a set of Dynomax Cerama-coat headers and don't want to drill them if I can. Can the hoses coming off of the diverter valve be put into a "T" pipe and then run straight to my new catalytic converter? The new cat has an air hose on it.
Thanks,
Matt
Old Sep 3, 2001 | 12:59 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should have gotten headers with the A.I.R. pipes already welded in.
I'm a little surprised to hear you don't have A.I.R. going to the cat. What year/drivetrain is your car? It's not Canadian, is it?
FWIW, my '84 full-size van has the pipes to the manifolds only as well. When I flunked emissions back in February, I put on a universal cat that had the A.I.R. pipe on it. I just kept it capped, passed with flying colors with the new cat. Runs better, too.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
